0 members (),
177
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 5 New Guy | | New Guy Joined: Mar 2016 Posts: 5 | Hi does anyone know if you can use the original 4 speed torque tube gearbox with an open driveshaft and new rear end? I just want to make the 1/2 ton less of a mobile roadblock Thanks Jon | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | yes you can, find a gear box from a 56 to 67 sm420 and use it or you can change out the coupling. It not that hard or take it to a trans. shop and they can do it for you. There is a trans. shop on line that sales the part you need but I don't remember the name. root | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Larger trucks also used a SM420 with an open drive shaft. 4 speeds with open drive shaft are actually more common than closed drive shaft. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You should be able to sell the enclosed drive-shaft rear-housing/cover.
Also, you should be able to sell the u-joint assembly (keep/save all parts), if you do not use it.
| | | | | Joined: Mar 2016 Posts: 5 New Guy | | New Guy Joined: Mar 2016 Posts: 5 | Thank you all for your input and help | | |
