5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#1152605 02/29/2016 3:36 AM
Ok on my 53 1/2 ton 5 window I put aftermarket master cylinder brake booster combo on under cab original location. 350 small block, pedal is hitting spark plug wires and will hit headers if pedal travels far enough. Not sure how far pedal needs to go yet. I was thinking of shortening arm by about an inch to correct. Then move hole in floor down to meet. Any ideas? See picture on Facebook. Chris naggy thanks
I just got done putting a BB mopar in my 52-3100 I had the same problem what I did was bend the pedal arm between the pedal and the master about 6 inches from the top toward the drivers side.I had to bend it about an inch and a half ,than I removed the felt pocket welded the hole and relocated the pocket for the round arm.Also I heated the arm and turned the pedal so it is level again.
Pete
