0 members (),
140
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | How does the wood attach to the front panel? It looks like the bed strips, stop short of the front panel. But there are multiple holes on the front panel. Pictures would be a great help.
Steve
'46 Chevrolet 1/2 T. Pickup, survivor - sold '31 Ford Model A pickup
| | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | Nobody has any pictures of the front panel to wood mount?
Steve
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |
Harold Is a restoration ever finished? | | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | Holes are drilled into the bed wood to align with the holes in the front bed panel. Carriage bolts pass through these holes to attach the wood to the bed panel. | | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 |
Steve
| | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Some of the 46 front panels had two bolt patterns in the lower flange. You don't need to put a bolt in every hole, just use the ones that are near the center of each board. And your bed strips should extend to nearly touch the front panel. The bed strips do not attach to the front panel. | | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | Thanks. My strips do stop short of the panel. I way wondering if a washer and bolt attached between the two boards and bolted to the panel, or bolted thru the board to the panel?
Steve
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Check out the mar-k.com site. Lots of info on truck beds. My truck is not with me but as I recall there are no cariage bolts through the front bed panel and rub strips. Abut 2-3 inches back a brace goes under the bed wood and that is where the carriage bolts are including the two large cam washers and bolts to bolt the bed to theframe. mar-k had most of the dimensional information. | | |
