0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#115264 04/22/2005 4:40 AM
I painted the bed of my truck last summer (it is off of the truck) with bc/cc and it has been sitting in the yard every since. I was hoping to finish the rest of the truck last year but I had an accident and was unable to get it done. The bed is really nasty from stuff getting on it and washing will not remove everything. I have tried polishing compound but that is slow going and very time consuming.
Is it possible to wet sand with a very fine paper to remove the surface gunk and then shoot clear on it again? Does anyone have any experience with the clay that is used to clean paint surfaces, if so, how good does it work?
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
#115265 04/22/2005 6:47 AM
When I did my bed I put 3 or 4 coats of clear. I used fine sandpaper between each coat. I'm not a painter but I would use a 600grit paper and remove all the gunk you have. Then shoot on the clear. I don't think the clay bar is going to be any easier than the polishing compound.
Cecil..........
#115266 04/22/2005 8:16 AM
400 or 600 wet sanding is what you gotta do
DustyG.
1952 Chevy 1.5 ton
1949 Gmc 2 ton flatbed Dump
#115267 04/22/2005 4:05 PM
Thanks guys, think I will wet sand as suggested.
Ralph Davis
#115268 04/22/2005 5:06 PM
U might want to try the clay bar first, some of the guys over at www.hotrodders.com swear by the stuff.
#115269 04/22/2005 11:56 PM
I have used the clay bar. Works great for taking off bee pollen and stuff like that. I was introduced to the clay by my son, who at the time, was detailing for a dealership.
I agree, try it first.
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
#115270 04/23/2005 4:23 AM
Thanks for the heads up on the clay bar. I will have to check it out because the paint job is in great condition, I really don't want to sand unless absolutely necessary.
Ralph Davis
#115271 04/23/2005 5:23 AM
I
I Offline
clay magic is available at any auto parts place, so is the macguires car clay.
I used it on a 1994 accord and was very impressed.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#115272 04/25/2005 1:55 AM
If the paint is good I wouldn't use anything as course as 600. I think anything you do will be time consuming.
Jim
#115273 04/25/2005 3:19 AM
If your going to re spray you have to cut with 600 anything less you wouldnt have good enough grip for the new clear or paint to cling on to.
DustyG.
1952 Chevy 1.5 ton
#115274 05/01/2005 3:17 AM
Tab Offline
Get a good polisher with a wool wheel and some polishing compound. It will not only get rid of the junk but it will leave a really high gloss finish.
delete my account and pictures
