| | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Removing my steering box and column to overhaul. When its ready to come out, which is the best way, out the bottom or over the fender? standard steering 53 3100 root | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I took out my steering column in my '53 3100. I had to remove the left brace (firewall to fender) and it came out over the fender. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think I got it out (and back in) from underneath, with the truck/frame jacked up and resting on high jack stands.
Do not forget to take out the "hidden bolt" that is underneath the box/frame (and often covered/hidden with caked-on grease/dirt).
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | thanks,1953 panel and tclederman for the input, looks like its 50/50 on the removal. I have it all loose ready to go. The hard part was getting the pitman arm puller on to pull the pitman. Had to use the smaller puller and had to remove some of the material from it to make it fit. 53 3100 root | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe the procedure is in the shop manual. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | truckernix, I forgot about the manual, looked and it and sounds like you have to take the fender skirt loose and bend out of the way. Think I will try one of the top to reply's first. root | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Just removed the box and column out the top. Took off the brace, bent the fender skirt out of the way, slid the box inboard, rolled it over 180 deg. and out over the fender. thanks for the input, you guys are the best. root | | |
