7 members (Donf, Goach2, Hanks custodian, rfs56trk, Rusted Nut, Bill Hanlon, 1 invisible),
56
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | 1950 3600 with the 235. they rebuilt the carb, but still cant get it to run right, and have decided that the carb isnt fixable, and it needs to be replaced. Unfortunately all the places i have found are all on back order. Do you guys have any advice?
Thanks!!
1950 Chevy 3600
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Did it run before you sent it to the shop?
What carb do you have?
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | It never ran right. It hasnt been driven in 15+ years and is just now at the end of a full frame off restoration, and this is the last thing to complete. its the single barrel rochester. the engine is out of a 1958 chevy if that matters.
1950 Chevy 3600
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Brad without knowing if the shop troubleshot the entire engine as a whole and then determined it was the carb that was causing it to run poorly, assuming it is the carb, we have vendors who sell replacement Roch Bs, but I would get a second opinion on the Carb before replacing it. Lots of young mechanics that do not know how these vintage carbs work WOULD throw up their hands and tell you to get another one. | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Brad without knowing if the shop troubleshot the entire engine as a whole and then determined it was the carb that was causing it to run poorly, assuming it is the carb, we have vendors who sell replacement Roch Bs, but I would get a second opinion on the Carb before replacing it. Lots of young mechanics that do not know how these vintage carbs work WOULD throw up their hands and tell you to get another one. Thanks. He even sent it over to another mechanic for a week or so, and he came to the same conclusion... but who knows.. Do you know where i could get a replacement?
1950 Chevy 3600
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | "It's the carburetor" is the last retreat of an incompetent mechanic. A carburetor is nothing but a chunk of metal with a bunch of precision-drilled holes in it- - - -there's not a whole lot that can go wrong with it. If the throttle shaft bores aren't worn to the point that it's leaking a lot of air around the venturi, and the carb is correct for the engine it's on, your problem is most likely somewhere else. That being said, "Rochester" might be the problem- - - -"Carter" would be better! When Chevy began building their own carbs in the late 1940's instead of buying their carbs from Carter, the CEO of Carter vowed to sell a million replacement carburetors for Chevy engines. It took several years to accomplish that goal, but the 1-millionth Carter replacement for the Rochester got gold-plated and presented to the CEO of GM! Their slogan back then was "The ABC's of carburetion are 'Always Buy Carter'!" Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just did a quick check and both the Filling Station and Jim Carter sell rebuilt Rochester Bs. I am sure all the others do too.
Personally I like the simplicity of the Rochester. There has been the odd one that I finally gave up on but generally they are a pretty easy rebuild. I have had one running my truck for the last nine years. | | | | | Joined: Feb 2002 Posts: 2,895 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,895 | Unfortunately all the places i have found are all on back order. Do you guys have any advice?
Thanks!! up top here on the bolt... links, then the parts section for a new or used one, services section for the rebuild places, go explore. -W | | | | | Joined: Nov 2002 Posts: 2,771 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,771 | The Rochester B's with manual choke for the 235 are difficult to find. Most of them have been thrown away over the years by disgruntled owners. The remaining units are in demand by a few individuals that want them for dual set-ups (easier to deal with the manual choke on multiple carbs). As far as the Rochester B's with automatic choke, we have been trying to GIVE them away for years, with little success! http://www.thecarburetorshop.com/Free_carbs.htmCarter manual choke carbs are almost as difficult in the 235 size. The manual choke 216 carbs are available. The 3211s Carter (Auto choke) replacement for the 1957-1962 235 engines are available. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | The Carter YF 2101s also fits the 235 from what I can gather.
Not uncommon to see rebuildable ones on eBay for reasonable prices.
1951 3100
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | For my 2 cents worth, If you are going to spend the money on a replacement, spend it on a Carter.
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Except for corrosion, everything else can be fixed - just not by that shop. | | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | Since you are having someone under the age of 80 working on your engine, you might want to check the carb gasket to make sure that it is correct for the carburetor. There is a hole which must not be blocked by the gasket. Carl
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I am a died in the wool Carter fan. Appears others are too.
I used Carb kings list and found them on E-bay. You may also find a W-1 , if you have the smaller spacing on your intake. There was a Stromberg on e-bay the other day as well. Have you made sure the heat riser is free and working correctly?
Do you have another carb for a Test?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Send your carb to Recarbo...they test and rebuild not just a dust and clean easy to do business with. Steve | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | "It's the carburetor" is the last retreat of an incompetent mechanic. That was my first thought when I started reading this thread!
Bill Burmeister | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Have you checked all the other variables such as: compression, timing, coil, all the components of the distributor, spark plugs, spark plug wires, fuel pump, etc.?
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I agree with who me, recarbo...... they rebuilt the one I had on my 52, got it back,installed, never touched it, purred like a kitten, it was still running well when I sold the truck some 6 yrs later... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Carter/Rochester. Either one could have worn throttle shafts/bores. These old carbs are relatively simple, as Jerry says. This is why, sooner or later, you need to rebuild one or learn to examine the workings a little. What kind of shop would rebuild a carb that can't be rebuilt? What is easier than a 1 barrel? If carbking will sell you a carb that is suitable for your motor, you may consider purchasing or having yours rebuilt. Click his link to inquire. He has some "trading" options that may save you money if you have any of the items.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | "It's the carburetor" is the last retreat of an incompetent mechanic. So if it turns out to be the carb by chance is the mechanic still incompetent? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | So if it turns out to be the carb by chance is the mechanic still incompetent? If overhauling the carb fixed the problem, then no. But most problems that are diagnosed as "carburetor problems" are actually caused by the ignition system.
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | What if he rebuilt the transmission and then said the transmission isn't fixable and needs to be replaced?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | he would be running for president Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Bart what you asked a post earlier reminds me of AAMCO. (Double A BEEP BEEP -M-C-O) | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yep, and they are still in business around here.
