7 members (Hush, Joe W, Peggy M, Jon G, Gray_Ghost, Guitplayer, 1 invisible), 160 guests, and 2 robots.
Topics128,101
Posts1,056,179
Members48,436
#1151975 02/25/2016 5:53 AM
They have no spring and the mc cap is vented. My 34 Chevy has discs on all four corners, everything new and near zero run out so figured 2# residual pressure valves not needed--wrong. My porta power ram draws back but figured reservoir is not vented so vacuum is formed. Conversely the ram on my big press needs two strong springs to retract it. What's happening?
Evan
back yard wrench turner
Where is your M/C located? If under the floor, gravity will draw the fluid back. This is why the residual valves are needed.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
In You're porta power there is a spring on the inside of the ram.Disc brakes don't really retract they just quit squeezing on the rotor when you let you're foot off the pedal.Disc brakes don't need residual valves gravity is not going to force the caliper to retract.
Pete
There is a spring in the M/C that will also draw fluid back.
Wayne
1989 Silverado
When there is no hydraulic pressure on the pad it is not pushing
on the disc so there is very little friction between the two.
The disc cools down quite rapidly when the friction is reduced
therefore it shrinks a few thousands creating a clearance.
dg
Denny G
Sandwich, IL
Riding in the Passing Lane
The seal ring inside the caliper is at a slight angle. The lip of the seal pulls the piston back just enough so it doesn't drag the lining.
1972 Chevy c10 Cheyenne Super
If the disc is not running true that could also bump the piston back a tad.
•1952 Chevrolet 3800 pickup
---All pictures---
All true, but the seal in the caliper does most of it. They are square cut on a slight angle, the fluid pushes the piston and seal, when released, the seal pulls back into shape bringing the piston with it. I have been running disk/drum set up since 1999 with no hold back valves, didn't know I needed them. Pedal is stiff each time i need it and master cylinder is the original location.
Pete
Not true. Depending on the master cylinder location, some disc brake setups need a 2PSI residual valve.
My 46 GMC on Photobucket
Thanks everyone,
Master cylinder is frame mounted and pedal gets hard one inch from floor. Pump once and has half pedal; twice and full pedal. Pedal stays hard in each location. With new rotors, bearings and spindles I get less than 0.001 run out so knew something had to be retracting the pads.
Evan
Originally Posted by coilover
Thanks everyone,
It's common to need residual valves with a frame mounted master cylinder.
