0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
I know this may be the wrong location for this, but I basically painted the inside of a gas tank, so I'll post here:
I am in the throes of restoring the gas tank from my '74 Honda motorcycle, and it had some minor interior rust, so I decided to try out the POR-15 tank kit for bikes. It came with a quart each of Marine Clean and Metal Ready, and a half pint of sealer. The tank is built of pretty thick metal, holds about 4 gallons or so, and has a somewhat convoluted bottom. I stripped the outside and removed all the hardware including the petcock and filler cap.
Last night I sealed the petcock hole and mixed up a batch of Marine Clean with hot water, and filled the tank with it and left it in the sun for a few hours. I drained it an rinsed it and got a concotion that looked like iced tea with clots in it.
Then I filled the tank with the metal ready (Phosphoric acid) and sloshed it around for a half hour. Man, that really cleaned the thing out, there was not a spot of rust in there afterward. It looked really good and I could have probably left it that way, but I think it would have rusted again since there was no oil protecting it from the air.
Finally, I poured in the sealer and sat on the porch and sloshed the tank over and around for 30 minutes, and drained the excess (to prevent puddles).
It looks like I painted the inside of the tank silver. It is pretty strange looking stuff. Now I have to wait a few days to put fuel in it, but it looks great in there. I still have to prime and paint the outside. I already filled a couple of dents and it should be ready to go in a week.
It looks like it will work really well, and I hope the liner lasts a long time because it would be a major pain to strip it out of there.
Paint & Body Shop moderator
Thats good to know. I have a few old snowmobile tanks i need to do.
47.5 Loadmaster 5 window
48 Chevy 3600
69 GTO convertible
Socket Breaker
Socket Breaker
Thanks for the review.
Lets us know if it holds fuel. smile
-W
i did the same thing with the same stuff only i never put gas in it after a year i looked in with a light what a bummer it was peeling im thinking you need to put gas in it and keep some in it to keep the sealer from getting to dry the guys from por would not return my messages i still have some i may try it again but next time ill buy a new tank instead of sealer or a good used tank that needs no sealer
