| | | Forums66 Topics128,057 Posts1,055,810 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 9 Member | | Member Joined: Jan 2003 Posts: 9 | I just got five new tires on my stock wheels, size 16 x 6.5LT. They look great -- problem is I cannot mount the spare on the side, as it needs about another inch of clearance at the fender. I've adjusted the mount all the way up, and its still not enough. Short of fabricating a new mount, have any of you guys found a solution? Jason 1953 3100
Jason Marshall 1953 Chevy 5-window, 216,
| | | | | Joined: Jan 2003 Posts: 9 Member | | Member Joined: Jan 2003 Posts: 9 | After a bit more research, it looks at though there are two different sized mounting brackets, one for the 6.00 and one for the 6.50. Can someone confirm this? Jason
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 |
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2003 Posts: 14 Member | | Member Joined: Jul 2003 Posts: 14 | Jason, I think your are right about the 600 and 650 but I thought you could ajust the rack to suit. But, who am I to say.
Craig, thanks for the compliment. | | | | | Joined: Jan 2003 Posts: 9 Member | | Member Joined: Jan 2003 Posts: 9 | Ron, BTW, your truck looks awesome! I've adjusted the mount as much as I can and still cannot get it to fit. Not sure what to do some except modify the mount.
