7 members (Opelika Tom, JW51, Crimson48, klhansen, 46 Texaco, ndkid275, Stan 58),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,085 Posts1,055,969 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | Have a 235 that is running ok, had head rebuilt due to radiator issues, also new oil pump. Have low oil pressure and engine is now "loud", kind of diesel like. Is there an adjustment to be made or is a rebuild a must. I ask because I have been told both. HELP! Thanks! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What original year/application engine?
Have you adjusted the valves? Have you tuned the engine: points, plugs, timing, carburetor. Were adjustments/tuning done per Shop/Owner's Manual - what year manual?
Who told you to do a rebuild? What is your oil pressure at idle (400-500 RPM)? What is your oil pressure at 1,000+ RPM? | | |
