1 members (TooMany2count),
82
Mod | | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 13 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 13 | I bought a slightly used 59 Apache short base with most of a fleet side, sand blasted and primed. This is a secondary project so it will not get the attention it deserves for a while but I look forward to seeing all of the other projects and trucks out there. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome YCgoat. You must have something extraordinary if it ranks higher than a slightly used Apache. Lots to see here, check out the gallery. Leo | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Welcome to the Stovebolt !!
see you are from VA, also from VA here 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Welcome YCGoat, A lot of great people here. You'll be surprised who might be next door to you. Check out the side lot and find out. There is also a lot of knowledge, tips, and beautiful trucks in all stagtes of a build. Post your questions, comments, and advice in the appropriate section of the forums best results.
Also, you might want to get a hold of 52Carl and Safetynut for Tidewater Luncheon details.
Post some pictures when you can.
Bread .
