2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 39 Junior Member | | Junior Member Joined: Jul 2004 Posts: 39 | Hi everyone, I am installing missing bed angle strips on my 1958 step side. Could anyone please check the distance from the top of the bed side to the top of the angle strip and send it to me. I have no reference to go by. Thanks Paul
Paul
When you do a good deed, get a receipt just incase HEAVEN is like....the IRS
| | | | | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | The angle strips were apparantly installed at the factory where the side was made and shipped to the assembly plant that way, so the assembly manual does not give that dimension. However, it does list the dimension from the top of the side to the top of the wood as 17.5625". The wood at the angle strips are not grooved as are the others. | | | | | Joined: Jul 2004 Posts: 39 Junior Member | | Junior Member Joined: Jul 2004 Posts: 39 | Thanks Chuck but I have my bed in pieces in the shop so the bed wood wood not help. I hope someone can measure thier bed from the top rail to the top of the angle piece. Thanks Again Paul
Paul
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Measure down 17.562 inches and let that be the line for the BOTTOM of the angle. I think I said that right!! | | | | | Joined: Jul 2004 Posts: 39 Junior Member | | Junior Member Joined: Jul 2004 Posts: 39 | Thanks train Driver & Chip. That will work. Paul
Paul
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Don't mean to toss sand into the gears but just in from the garage where my 59 with factory spot welded angle strips measure 16.5 inches from the top edge of the strip to the outgoing bend at the top of the bedside. I measured front, center, and back of both bedsides with less than 1/16 inch variation. Hope this helps.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
