4 members (Otto Skorzeny, Materman, mason86, GRNHydra), 100 guests, and 2 robots.
Topics128,069
Posts1,055,890
Members48,428
#115126 09/30/2004 8:47 PM
Junior Member
Junior Member
Hi everyone,
I am installing missing bed angle strips on my 1958 step side. Could anyone please check the distance from the top of the bed side to the top of the angle strip and send it to me. I have no reference to go by.
Thanks Paul
Paul
When you do a good deed, get a receipt just incase HEAVEN is
like....the IRS
#115127 10/01/2004 11:02 AM
Got your bedwood (or reasonable facsimile 3/4" thick)? Angle strip sits on the wood.
http://www.chuckthetruck.homestead.com/page8.html
#115128 10/01/2004 12:52 PM
The angle strips were apparantly installed at the factory where the side was made and shipped to the assembly plant that way, so the assembly manual does not give that dimension. However, it does list the dimension from the top of the side to the top of the wood as 17.5625". The wood at the angle strips are not grooved as are the others.
Junior Member
Junior Member
Thanks Chuck but I have my bed in pieces in the shop so the bed wood wood not help. I hope someone can measure thier bed from the top rail to the top of the angle piece.
Thanks Again Paul
Paul
like....the IRS
Measure down 17.562 inches and let that be the line for the BOTTOM of the angle. I think I said that right!!
#115131 10/02/2004 12:39 AM
Junior Member
Junior Member
Thanks train Driver & Chip. That will work.
Paul
Paul
like....the IRS
Don't mean to toss sand into the gears but just in from the garage where my 59 with factory spot welded angle strips measure 16.5 inches from the top edge of the strip to the outgoing bend at the top of the bedside. I measured front, center, and back of both bedsides with less than 1/16 inch variation. Hope this helps.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
