| | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | Hi out there - Anybody have any experience in repairing a clamshell top lift gate in good condition? Mine has cracks in the metal where the hinges bolt on. . . Thank you -
personal buying/selling should take place in the Swap Meet -- edited by Moderator --
| | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | Weatherstripping for a '52 suburban clamshell...
Found a great welder for the hinge repair. Now the next problem - anybody have a supplier for the rubber weather seal for the upper and lower clamshells? Most suppliers don't seem to have this product - any luck with more generalized part solutions?
Thank you
Lisa
1952 Chevy Carryall in completely original condition Pulled out of a barn in Colorado high desert
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have a sample? If you do, post links to a few pictures - include a cross-section shot.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I would bet Steele has the stuff your looking for. Search the catalog and find the right profile. If they don't have it vehicle specific you can order the closest profile by the foot. Just give them a call.
| | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | I have removed some of the old weatherstripping. It has the same cross-section as the new door weatherstrip. However, I don't think it is correct or stock, because the gap shows air all around.
So I called Steele Rubber, and they provided a great suggestion: use some modeling clay; shape into a cylinder larger in diameter than the gap between the clamshell and the body; wrap in plastic wrap, feed into the gap, and shut the gate. Then cut the end of the clay with a sharp razor blade. The resulting shape should be a very good exact fit.
Anybody ever try this?
Lisa
| | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | appreciate any insight you all can provide.
Lisa
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | No, but Steele are the experts in the field. Follow their suggestion and you will be fine.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | That will give you the shape profile you need. Then what are you going to do?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | I found a fellow in Oxnard CA who is apparently a clamshell expert. But after the clay was removed and sectioned, I now have a good idea on what the compressed weatherstrip looks like. Going to go with a larger cross section and see how that works -
Lisa
| | | | | Joined: Feb 2016 Posts: 18 New Guy | | New Guy Joined: Feb 2016 Posts: 18 | Hi I have a question regarding frame off restorations. Is it really necessary to fix up my 53 suburban to a good quality "driver quality" can anyone give me a ballpark figure it would cost and would I just go to a body shop for this to be done? Thanks, kyron | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No it is not necessary to frame off restore one. Get it mechanically sound and drive it. Click on the link to my Suburban to see an example. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Kyron, click on my photobucket link below to see a frame off resto of my panel. $$$ spent depends on condition you start with. However, dropping 10-15 grand is easy, 15-20 will get you a nice job....if you do all the work yourself and want stuff new, nice used, repop or what ever you can find!!!
EDIT: it is not unusual for some to put north of 25 into one. Again, it depends on how much you do, and how much help from others. I'm not scared of talking numbers. My rust bucket had LOTS of work to do, check the photo's, and I'm north of 18 grand and haven't added up some stuff. That's with new motor/trans/wheels/tires/brake system, exhaust system, interior (headliner not in yet) new floor pans, All glass, new radiator, PS pump, alternator, grille, bumpers, wiring.... and the list goes on and on. I think you can see the point. Or, like Cletus, find you a good one and keep on trucking. I just enjoy the work/build. I even had some free stuff given to me! Oh, and did I mention the 6 years working on it!!
| | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | From what i found out, most people use the standard door weatherstripping for the clamshells, both the top and bottom lift gate. I plan on using a slightly larger profile of the weatherstrip gasket. Armand says that they never seal at 100%, but many do come close.
He also said that the hinges need to be lubricated often to work properly, with a light grease. Hope this helps folks out there with Clamshell suburbans in need of weatherstripping.
Best Regards, All
Lisa
| | | | | Joined: Feb 2016 Posts: 18 New Guy | | New Guy Joined: Feb 2016 Posts: 18 | Hi I'm new and I have a 53 suburban. My clamshell hinges both top and bottom need repair. I live in Ventura, next door to Oxnard. Could you share any contact info on this person? Thanks, kyron | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | What repair do they need? | | | | | Joined: Feb 2016 Posts: 18 New Guy | | New Guy Joined: Feb 2016 Posts: 18 | Pretty bad. The top right hinge is completely torn out of body and the two bottoms are cracked around hinge on tailgate and rust issues as well. | | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | Hi Kyron, PM me and I'll ask him if he's available. Best, Riverdancer
Lisa
| | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | We repaired the cracked lift gate yesterday. Welded in a new small plate around the top to accept the hinges. Painted and lubed the hinges. reinstalled the window glass with a new seal from Steele Rubber. Then installed the liftgate-to-body gasket (same gasket is used on the front two doors). And then, Reassembled all parts - it works very well!
Lifts and closes easily, and mates well to the body. A successful repair!
Lisa
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Congratulations
Post links to photos so we can see what you have done. | | | | | Joined: Feb 2016 Posts: 18 New Guy | | New Guy Joined: Feb 2016 Posts: 18 | While my 52 suburban is at body shop, I need to find the glass for all four side windows. I thought I saw some on a parts website, but can't recall which one. As long as I have the cracked glass for a template, is it more cost effective to just have them made at auto glass shop? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | As long as you have the original glass, I would take them To your local glass shop. You'll save some money doing so.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I whole hearted agree with Tim but I must warn you. Local shops around here do a good job but I have found that they will leave it "straight cut" unless you mention it to them before they cut it. I insist that the lady or man who writes up the order to be sure to note on the ticket that the EDGES must smoothed. I learned the hard way. I still use the same shop but I do have to tell them. | | | | | Joined: Feb 2016 Posts: 18 New Guy | | New Guy Joined: Feb 2016 Posts: 18 | Thanks guys I appreciate your advice. Kyron | | |
