| | | Forums66 Topics128,086 Posts1,056,331 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | I'm finally seeing some progress putting the truck back together. Just about have the clutch linkage figured out (235 6 cylinder with granny tranny), but am wondering where the front hook of the spring mounts. There's a pic in the assembly manual which appears to show a bracket mounting to one of the oil pan bolts that doubles as a carb linkage spring bracket. I cannot find anything like this in my pile of "stuff". I also cannot find anything like this in my parts catalogs. Could someone post a pic of the bracket both in and out of the truck? If no pic, maybe a part number or where to get one? Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's just a small right angle sheet metal tab, you'll hafta make your own, not likely to even find a used one as they're always "lost" the first time the pan is removed
Bill | | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | Thanks, Bill. That's what I'll do. | | |
