5 members (Oswald, 2-Ton, 1955 1 Series, Peggy M, Hotrod Lincoln), 75 guests, and 2 robots.
Topics128,089
Posts1,056,352
Members48,442
I'm finally seeing some progress putting the truck back together. Just about have the clutch linkage figured out (235 6 cylinder with granny tranny), but am wondering where the front hook of the spring mounts. There's a pic in the assembly manual which appears to show a bracket mounting to one of the oil pan bolts that doubles as a carb linkage spring bracket. I cannot find anything like this in my pile of "stuff". I also cannot find anything like this in my parts catalogs. Could someone post a pic of the bracket both in and out of the truck? If no pic, maybe a part number or where to get one? Thanks
it's just a small right angle sheet metal tab, you'll hafta make your own, not likely to even find a used one as they're always "lost" the first time the pan is removed
Thanks, Bill. That's what I'll do.
