1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1150845 02/18/2016 6:01 PM
I picked up an original all numbers matching (or as far as I could tell) 1949 chevy 1/2 ton truck it has a straight 6 in it and I was wandering if someone knew of an electronic ignition for it ? I have looked all morning and I find stuff for the 55s and up but nothing from the 49 to 54 stuff. Thank you guys in advance
frankenstein Fabrications
Crusing in the Passing Lane
Deve on here has one, '55's are the same except some have juice lifters.
Ed
jpmanyhearts,
You might want to post your engine serial number (pressed into the block behind the distributor).
If you have a 1949 engine, it has mechanical lifters.
Do you still have a 6v system?
Riding in the Passing Lane
Pertronics has a kit to change over to electronic.
1972 Chevy c10 Cheyenne Super
yes........well it had it some one robbed the generator voltage regulator and rediator off of it si im thinking ill just do a 12volt swap
