3 members (RonG, Forty9, Jon G), 126 guests, and 2 robots.
Topics128,163
Posts1,056,964
Members48,458
Last time I worked this part of the truck was 1977 on my Honeymoon I replaced the gearbox on my 54 panel.
You might say I am a bit rusty, the question is when I let go the ball cover and u joint will I be able to pull the ball cover off without having to remove anything else. Want to replace the gaskets on a 54 torque tube pickup I am working on.
Len
layback
ODSS Lawman
ODSS Lawman
You will be able to slide it back. The only way to remove the cover is to unbolt the U-joint.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
When ahead had no problem drive shaft came down plenty to do the job.
layback
