1 members (TooMany2count),
120
Mod | | | Forums66 Topics128,193 Posts1,057,257 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 71 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 71 | Hi guys Me and quite a few other people here are making the same mistake when we rebuild our brake related parts . We lube all up with Brake Fluid .This is a very bad habit . Why ,as we all know brake fluid attracts moisture and when we use brake fluid as lube we invite moisture in to start it's nasty deeds all over again . While I was in Europe (Austria)brake assembly grease is in all the auto parts store .I started to use it with very good results . Back here in the states I finally found some . But before I found some here I did my brakes on my 48 2 ton wheel cylinders ,using brake fluid as a assembly lube well they are now sticking . When I was getting my 52 1 ton panel ready for a road trip to it's new home I found Permatex 24110 Ultra Disc Brake Caliper Lube . I called Permatex to be 100% sure this was the correct stuff to use and was told it was . That was 2013 and it still has great brakes . It's not cheap ,but doing some research to write this here I found some on Amazon offered from Permatex for very good price . http://www.amazon.com/Permatex-24110-Ultra-Brake-Caliper/dp/B000HBNV6W When I do a wheel cyl or a master cyl I make sure that the back side of the cups or piston get a good greasing also with the lube also . You guys that don't put so many miles on your trucks unlike me who does and they sit around a bunch this is just the stuff you need . Well I hope this bit of info helps a lot of people . Paul
1948 Chevy 2 ton flatbed ex fire truck , and various motorcycles .
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Good God this is large print. I'll have to remove my spectacles...
Brad Wrench Fetcher, PhD | | | | | Joined: Jul 2010 Posts: 10 New Guy | | New Guy Joined: Jul 2010 Posts: 10 | | | |
