3 members (klhansen, ronsway, 1 invisible),
165
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 3 New Guy | | New Guy Joined: Feb 2016 Posts: 3 | http://www.ebay.com/itm/GMC-Other-/131723841848?forcerrptr=true&hash=item1eab5a5138:g:mCQAAOSwnLdWsAZb&item=131723841848 | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Fixed your link. Harold Lift Truck
Harold Is a restoration ever finished? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Okie, so you don't draw the wrath of the moderator(s) stovebolt has a specific forum for Ebay and Craigslist links. They won't bite you but they might slap your hand.
| | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | Oh, that is so cool. Don't let John see it. Although, I can see a barrage of ODSS members coming up here to "help" John and doing who-knows-what with this scissors truck!
Impressive.
It's not so bad to have it listed here since the BB forum are pretty hard core. They may not look at the eBay and Craigslist forum. Hmmmm .. I take that back: they probably search those two SITES regularly for stuff like this.
We can post it in both places. Thanks for being diligent tho Martin and thanks Harold for fixing the link!
Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Its a neat piece of machinery. But with no outriggers, I'm not sure what a person would do with it. If it were a 550 series with an Olds engine and air brakes, I think I would do some serious thinking. I've got the glass that's missing. And it looks like the guy has a lot of real estate to keep it until the weather gets better. I would have to take a semi up there. I wouldn't try to haul it on a goose neck. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It appears as if those scissor arms are solid steel, if so that mechanism and steel deck is seriously heavy before putting anything on it.
I can't make out what is on the door, wonder what it was used for. I've seen similar at the airport but nothing this heavy. The airport idea could explain the lack of outriggers, not so necessary on dead flat concrete. | | | | | Joined: Aug 2001 Posts: 3,599 Moderator | | Moderator Joined: Aug 2001 Posts: 3,599 | A lot of iron for that price! Would make a good Mardi Gra float/dance floor.
Don
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jan 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 42 | Man, I'd love to have the cab. It would look good on my 2 1/2 ton military M35. | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | Someone let Mongo know. They could use it in KC for the band
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Rare 5-Window Blue Chip Cab!! "Civil Defense" is the emblem on the door. I'm interested in the driveline set-up! Juice,or air brakes?? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I'm pretty sure it is hydraulic brakes. It looks like a brake pedal all the way down to the floor. This is what air brakes would look likel https://plus.google.com/u/0/1126369...6411612146&oid=112636930370126476644Also, I don't see any air chambers in the picture from the rear. And I'm not sure they made brackets for a compressor for the Pontiac engine. The engine would probably be a 336 Pontiac. The transmission might be a New Process 540 or 541. The suspension appears to be Hendrickson and the rears appear to be Eaton. It could be one of those goofy Eatons with the drive shaft going to the rear over the forward axle instead of a throughshaft like Rockwell used. A first glance, it looks like one of the food service trucks at an airport, but it is way too heavy for that. Just a wild guess would be that it was used to load weaponry into B52s. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I didn't see the extra gear shift levers for the Power Divider. I wonder if the rear rear is a tag? Mike B  | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Interesting "Cold War" Civil Defense Stuff! i didn't see any inside cab pics,just L.,R.,and front pic's.
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | If power divider is vac-operated,the switch may be mounted on/under the dash. My friend has a '51 G.M.C. Tandem. The power divider switch looks identical to the "bicycle Bell" 2-speed A.D. switches,except marked Wet/Dry,not Hi/Lo. From the looks of the hubs,both rear axles are "Drivers".
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I thought a switch marked wet and dry was to reduce air pressure to the front brakes? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The wet and dry usually does denote a switch that completely killed the steering axle brakes. A Bendix TW type switch, which is still commonly used, controlled a relay valve. And the switch on the dash was usually marked wet or dry. http://www.bendixvrc.com/itemDisplay.asp?documentID=2739If you scroll down on the pdf, it lists all the plates that are available for the TW type valve. Back then, it was thought that the steering axle tires locking up on wet or icy pavement is what caused a jack knife. However, since it has been learned that the drive axle tires locking up is what causes a vehicle to switch ends. In fact steering brake limiters or omitting steering axle brakes has been illegal since about 1989. I used to run with steering axle brakes omitted to save weight. I was forced to retrofit in 1989. Power divider locks are usually marked in and out, but I have never owed a twin screw that didn't have air. And they all shift with a Bendix TW type toggle switch. From the looks of the picture, it is Eatons rears because of the round banjo housings rather than the square Rockwells. It could be one of the goofy Eatons that had the interaxle driveshaft going over the top of the forward axle. They only built them a few years because the Rockwell with a throughshaft was so much more practical. I don't think the Eaton even had a power divider. I think they resembled a 4 wheel drive transfer case and was used on vocational trucks rather than over the road trucks. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I didn't see any inside cab pics,just L.,R.,and front pic's. Willy, There's a small left and right arrow on either end of the 4 eBay pictures that let you scroll through more pictures... Mike B  | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks,Mike! This G.M.C. I'm referring to,has a "bicycle Bell" type switch,Very similar to the 2-speed A.D. switches. this truck is equipped with juice brakes-No air-over-hydraulics. The switch is connected,(by vacuum lines),to the "power divider". Then,again,this is an early '50's G.M.C. Tandem 450. Kenneth is correct. The "power divider" resembles a transfer case,and the rear driveshaft goes over the top of the front axle,and connects to the rear axle at quite an angle. Probably a truck with a top speed of 40 M.P.H. This one was used as a dump truck in a quarry. Not much highway use for that truck.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Willy, Does the power divider also act as a aux transmission with double under, under and direct, or are the rears so low that's not needed and the switch just locks in the second rear only? Mike B  | | |
