2 members (Ponchogl, 1955 1 Series), 376 guests, and 4 robots.
Topics128,163
Posts1,057,044
Members48,463
#1150121 02/14/2016 4:39 PM
Last night as I was attempting to remove the rear wheels on 51 Chevrolet 6400 I ran into a problem and just wanted to see if anyone had a solution. I was able to remove the outer and inner wheel on the drivers side with no hiccups, however when I got to the passenger side a different story. Two of the lug bolts just spin when I try to remove the nuts. If you have come across this problem and have a solution I'd love to hear it. Thanks
Farmall140 #1150124 02/14/2016 4:45 PM
Impact gun might get them off.
If not remove the entire wheel, hub, and drum assembly. Weld a bar or something on the heads of the offending studs to prevent turning, then remove nut.
If you have a nut splitter or are real good and careful with the torch that's an option. In the end you'll still be removing the hub to replace the studs.
•1952 Chevrolet 3800 pickup
---All pictures---
Farmall140 #1150125 02/14/2016 4:46 PM
Riding in the Passing Lane
There are 3 different type wheels available back then. It depends on what type wheels & mounting you have.
1972 Chevy c10 Cheyenne Super
Farmall140 #1150126 02/14/2016 4:47 PM
There is a special wrench that surrounds the outer nut and locks against the wheel which allows you to tighten the inner nut. Any NAPA store should have one. This usually breaks the bond loose between the nuts and allows the outer nut to be removed. It's much easier with a 1" drive impact wrench- - - -hand cranking big lug nuts is a PITA!
Farmall140 #1150133 02/14/2016 5:11 PM
A 1951 Chevy 6400 has only simple 5/8-18 lug nuts, one per stud, hub centered wheels.
Jerry's solution is for Budd wheels with inner and outer nuts.
---All pictures---
Farmall140 #1150134 02/14/2016 5:20 PM
OOPS! I'm thinking "big truck" again!
