8 members (2-Ton, MNSmith, mick53, TUTS 59, Cletus1950, Peggy M, klhansen, EchoBravoSierra),
101
Mod | | | Forums66 Topics128,173 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 20 | ..Hi,,,,I swapped out a 235 ci in favor of a 265 V-8,,,,I attached my 3-speed overdrive….But the engine isn't long enough,,,Comes up about 4 inches short of the bell housing-to-crossmenber mounts,
Any help? What am I missing?
Love is blind᠁.but the neighbors ain't!
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy marc1955cameo, welcome, if you truck did not originally come with a V8 then you will have to purchase the factory mounts which were riveted to the front crossmember on V8 trucks, these mounts were not installed on non V8 truck chassis. There are many vendors which sell these parts alone or in a kit which includes all the components necessary to install a V8 in place of the six cylinder Jim Carter sells a complete kit their p/n HP122, hope that helps. | | |
