2 members (TexasJim50, Wally / Montana), 97 guests, and 0 robots.
Topics128,052
Posts1,055,743
#114873 04/21/2005 8:30 PM
Junior Member
Junior Member
I ordered one of the repro Fulton style sunvisors and it comes with the original olive green primer coat. When I paint this visor should I leave the bottom side of the visor in the primer coat, or paint the entire visor??
Any ideas??
#114874 04/22/2005 12:38 AM
I painted mine on both sides:
[img]http://www.whizzerick.com/shoptruck.JPG[/img]
I've read somewhere (cant find the link) that originals where flat green.
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
#114875 04/22/2005 3:35 AM
Even though it's not mounted I painted both sides. I also understand that originals left the bottom flat green. The reason, from what I understand is, they were concerned about the light reflection off the bottom. Cecil....
#114876 04/22/2005 5:10 AM
Jimmy is right; the primer on the bottem reduces the reflection off the hood. Same reason they primed all surfaces a pilot could see out of his windscreen on the WW II warbirds.
#114877 04/22/2005 8:18 AM
I would get a flat paint and paint over the primer. that way its nicly sealed and you dont have to worry and out.
DustyG.
1952 Chevy 1.5 ton
1949 Gmc 2 ton flatbed Dump
#114878 04/22/2005 9:22 AM
V
V Offline
this from the original instructions
STEP 4:When preparing the Sun Shield for final painting, the under side of the shield should be masked as show above, to preserve the dull green finish which has been baked on during manufacture. The under side should remain green since this has been scientifically determined as the color which absorbs the maximum amount of light, and therefore provides the greatest protection from sun glare. No further prime coat is necessary before applying finish coat to match the car. We suggest the use of synthetic paint rather than lacquer as a finish medium because of its greater durability. However, the prime surface now on the sun shield will take either a lacquer or a synthetic enamel finish equally well. The surface of the various parts of the sun shield must be absolutely clean before application of the finish coat. Grease or other finger marks on the surface may result in blistering or peeling of the finish coat upon drying. To clean, we recommend that the shield be wiped with a clean cloth which has been dampened with naphtha. After wiping, allow sufficient time for the naphtha to evaporate before painting. Painters are cautioned to make certain that there is no moisture or water in the air lines leading to the paint gun, as a film of lacquer or paint containing small droplets of water will blister upon dry
Gangster whites and straight pipes.....
