7 members (Hotrod Lincoln, Oldcaliforniakid, 49nut, frogfarmer, Stovebolt48, mason86, Woodcmiami),
89
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 78 | Today at work I had my '01 chevy parked beside the shop. The young kid that I work with decides to back the peterbilt tandem in front of the shop and do some touch up painting on the anhydrous ammonia tanks mounted on the back. This process, done with an air gun, is upwind of my truck.  So here I am with a slightly speckled BLACK truck. I tried rubbing it with paint thinner, and it works but you I have to rub very hard and it is painstakingly slow, not to mention probably not real good for the clearcoat. Any products out there that'll work better? Ideas? Thanks.
----------------------------------- Rollin' Hard 1946 Chevy 1/2 ton 1959 Phord 1/2 ton 2001 Chevy 1/2 ton
| | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | USE 000 STEELWOOL PAD FOR YOUR GLASS CHROME PLASTIC JUST DON'T ABOUT THE PAINTED SURFACE
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 |
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
| | | | | Joined: Aug 2003 Posts: 1 Junior Member | | Junior Member Joined: Aug 2003 Posts: 1 | Ditto On the body clay. I had the same problem and the clay worked wonders. I used clay magic it was under $10 at pep-boys. Just one note, keep it well lubed. The clay can leave streaks if you don't. Good luck,
Jeff | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I had my red Miata get tagged by a young hoodlum a while ago. He was using grey primer. Body clay wouldn't touch it, but laquer thinner did. I rinsed with water and re-waxed and you can't tell where it happened. I bet a two part paint product would be a pain to remove, just hope it dried in the air before it hit your paint.
