5 members (LAROKE, TUTS 59, Gdads51, MickeyP, Oswald), 108 guests, and 0 robots.
Topics128,049
Posts1,055,695
#114868 08/20/2003 4:37 AM
Today at work I had my '01 chevy parked beside the shop. The young kid that I work with decides to back the peterbilt tandem in front of the shop and do some touch up painting on the anhydrous ammonia tanks mounted on the back. This process, done with an air gun, is upwind of my truck. frown So here I am with a slightly speckled BLACK truck. I tried rubbing it with paint thinner, and it works but you I have to rub very hard and it is painstakingly slow, not to mention probably not real good for the clearcoat. Any products out there that'll work better? Ideas? Thanks.
Rollin' Hard
1946 Chevy 1/2 ton
1959 Phord 1/2 ton
2001 Chevy 1/2 ton
#114869 08/20/2003 5:55 AM
USE 000 STEELWOOL PAD FOR YOUR GLASS CHROME
PLASTIC
JUST DON'T ABOUT THE PAINTED SURFACE
FRAMEUP TRUCKS - 47/55.1ST
STILL PLAYING WITH TRUCKS
#114870 08/20/2003 7:22 AM
body clay
and buffing
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
#114871 08/20/2003 12:47 PM
Junior Member
Junior Member
2 Offline
Ditto On the body clay. I had the same problem and the clay worked wonders. I used clay magic it was under $10 at pep-boys. Just one note, keep it well lubed. The clay can leave streaks if you don't. Good luck,
Jeff
#114872 08/23/2003 12:21 AM
I had my red Miata get tagged by a young hoodlum a while ago. He was using grey primer. Body clay wouldn't touch it, but laquer thinner did. I rinsed with water and re-waxed and you can't tell where it happened. I bet a two part paint product would be a pain to remove, just hope it dried in the air before it hit your paint.
Paint & Body Shop moderator
