| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If convenient I wouldn't mind having the front half of a 48-53 (or 54?) GMC frame to help me figure out and modify the transmisison crossmember to suit my needs.
1 ton would be ideal but I think 3/4 through 2 ton uses same transmission corssmember, fits in the frame same way. Not sure about 1/2 ton.
All I need is from front engine crossmember to transmisison crossmember, though wouldn't hurt to also have crossmember behind cab.
Needs to be from a GMC because of the front engine mount.
Thanks, Grigg | | | | | Joined: Aug 2001 Posts: 3,596 Moderator | | Moderator Joined: Aug 2001 Posts: 3,596 | How about a 51 3/4 ton Chevy? The whole truck delivered to your shop in May, after we get the engine started at the Homecoming. Clean title in my name. http://s893.photobucket.com/user/2-Ton/library/1951%20no%20bed I'll get more pictures of the mounts later today. Price will be discussed privately. Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks but no thanks, really needs to be a GMC because the front crossmember is different from a Chevy.
Also hope to turn up half or whole frame less the rest of the truck. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Grigg, I have the chassis from the GMC Sleeper Cab project that John had...don't remember the size...2-ton??? You're welcome to any or all of the frame members you want, unless you already took them off! Mike B  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks Mike, I think that truck being a 450 series has a much different frame and cross members, particularly the rear engine mount. I'll look at the pictures I have of that truck tomorrow. Do know we saved and reused a U shaped channel iron crossmember from just behind the engine which is why I'm pretty sure not same as a pickup.
Really just looking for enough of a 1 ton or comparable frame to fit an engine in and mockup and fabricate a different rear engine crossmember. Be a lot easier to do that with a short section of naked frame than one with a cab on it.
Grigg
