7 members (Philipj, CharlieF, CATMAN, klhansen, fonz8261, Shade Baby, Phak1),
84
Mod | | | Forums66 Topics128,153 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | I didn't see anything with a search, so forgive me if it's been discussed. But I have a '56 2 ton, currently has a 283 and I'm wanting to put a 454 in it for more torque. (I haul gravel sometimes, heavy loads).
It looks like the heads might get real close to the firewall and steering sector? I'll have to build motor mounts but I'm not too worried about that. Anyone ever try this?
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Nothing that can't be overcome with a BFH and a torch. Guys do this swap all the time. Take your time to fit everything the way you like. There is a solution for all the fitment problems. Others will chime in who have done it. Great project and will be a hoot when finished.
| | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | Thanks Martin, I'm sure you're right, and I don't mind modifying the firewall a little, but that steering sector would be pretty tough to move without a lot of work. I have headers, and can mod them too, so there is that option. Dropping the block off today at machine shop, going with the summit 1301 cam, copying the Hot Rod Mag build they did with this cam/intake/carb combo, it made 511ft lbs of torque and 408hp. That should haul some rock...haha Nothing that can't be overcome with a BFH and a torch. Guys do this swap all the time. Take your time to fit everything the way you like. There is a solution for all the fitment problems. Others will chime in who have done it. Great project and will be a hoot when finished. | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Welcome to the Stovebolt  The BB should bolt right up to the bell housing, add side motor mounts and your done...almost! I think you'll need to use rear dump exhaust manifolds to clear the stock steering. Not trying to change your mind, but a 350 would bolt right in and give you all the power you would need. My 8400 Tow Truck has a 350 2-barrel with stock 4-speed trans and 2-speed rear and I can cruize at 65 mph all day long. The Rams Horn manifolds fit with no alterations needed. Don't forget to replace all of the brake lines (steel and rubber) as the fail from the inside out. I would not trust 60 year old lines. What trans do you have? What Series is your truck? Pictures? Mike B  | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I'll second what Mike B. said. Also, if you put in a BB, you may also need to beef up your cooling system.
My 59 1/2 ton Suburban has a 350 and SM465 (not quite as low of granny as the stock SM420). I have a 3.40 rear end in it (not as low as stock 3.90) and was able to get my 58 2-ton on a trailer moving along just fine. I weighed 17,340 when I rolled across the scales. A 350 should have a lot more torque than the 283 (could also go to a 383, which is a bit longer stroke so more torque than the 350). 454 is doable, but may not need it. | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | Thanks for all the input!!
Martin: good point, I don't mind "massaging" the firewall if I have to but the steering sector is what worries me.
Mike B: True, a 350 would be fine, but I already have this 454, it's in good shape, and to tell you the truth I just love big blocks. It's dumb, I know. But it'll be a kick to drive.
I don't know what tranny it is, but I'll find out soon when I pull it out, I'm going to have 3rd gear fixed, it pops out sometimes.
I'll go dig up some pics and report back
| | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | Good point, I am planning on a new radiator, the old one is shot anyway. I'm up in the mountains, and going up big long hills with a full load of gravel is pretty rough. With my luck I'll probably twist a driveshaft with all this torque..ha I'll second what Mike B. said. Also, if you put in a BB, you may also need to beef up your cooling system.
My 59 1/2 ton Suburban has a 350 and SM465 (not quite as low of granny as the stock SM420). I have a 3.40 rear end in it (not as low as stock 3.90) and was able to get my 58 2-ton on a trailer moving along just fine. I weighed 17,340 when I rolled across the scales. A 350 should have a lot more torque than the 283 (could also go to a 383, which is a bit longer stroke so more torque than the 350). 454 is doable, but may not need it. | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | Martin, Mike B, I typed out a response but it's not showing up. Maybe waiting for mods, but the reply to 69Cuda showed up right away? At any rate, thanks for the input! I'm not sure on tranny details yet, but i'll be pulling it out soon to have 3rd gear fixed (synchros, probably). I do have headers for the 454, so I can modify them if needed to clear the steering sector. Nothing that can't be overcome with a BFH and a torch. Guys do this swap all the time. Take your time to fit everything the way you like. There is a solution for all the fitment problems. Others will chime in who have done it. Great project and will be a hoot when finished. | | | | | Joined: Jan 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 42 | Just for discussion sakes, how about a diesel, 5.9 cummins. I haul a lot and am planning on a diesel swap. I'm guessing you already have a 454, etc., so saving money would be a factor. | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | I would love to have a 5.9 in there, but it's a lot more money and hassle to convert than I'm willing to tackle right now. | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | Not sure how to embed pics, but there are two links above to a couple pictures of it | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | 8flat, I understand about going up hills with a full load. Pulling the 58 up the I-90 Vantage hill I had to drop into 3rd @ 3,000 RPM and was barely able to hold it there. More torque (from the extra 100 cubic inches) would have been nice! Any idea how much do you weigh full of gravel? Sounds like you have a 454 already? That can tip the decision a bit!
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might see about talking to Grant Ensrud.
Bill Burmeister | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | doesn't look like Grant is a member on here any longer. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | An NP -540 series( 5 speed) come with Chevy bolt pattern, closer ratios for hauling loads. Al shift tower, 4 shift rails.
Ed
| | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | Yep I already had this 454 sitting around, I just dropped it off at the machine shop today.
Good question about weight, I have no idea. It has a massive spring pack and it'll squat right down on the overload springs.
Gary | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | I'd love to have a 5 speed. But I suppose I'd have to swap out crossmembers? An NP -540 series( 5 speed) come with Chevy bolt pattern, closer ratios for hauling loads. Al shift tower, 4 shift rails.
Ed | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | That is a cool truck. Wonder if he ever got it done? | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | You have the 2-speed rear in yours still, right? That should help with gear ratio... although I have not driven my 2-ton yet.
I also have a clark 5-speed overdrive I was planning in putting in mine, but it has an SAE #3 (I think that is what it is called) bellhousing so, I need an adapter ring from something like a C7000 to put it behind the Chev V8. | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | 8flat, You never said what series your truck is? To show us pictures you need to put your pictures on the photo host web site like Photobucket and then post the link to the picture. Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | SAE #2 bolts are 4.750" cl to cl, SAE #3 bolts are 4.375" cl to cl.
Ed
| | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | Yep I have the 2speed but it quit working a couple months ago, I need to check it out. Old original vacuum unit, so I'm guessing the rubber diaphragm looks like an old prolapsed cow. haha
How hard are they to convert to an electric style? | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | Sorry Mike I had posted some links to pics at the top of page 2 of this thread, did they not come through? It's a second series, if that's the proper terminology. Looks like a '57 chevy. I love the thing, kids love it, other gearheads love it, wife hates it. (it's stinky) HAHAHA which makes it even better. Gary 8flat, You never said what series your truck is? To show us pictures you need to put your pictures on the photo host web site like Photobucket and then post the link to the picture. Mike B
| | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | The Series would be 4400, 6400, 8400, 10500 etc., this tells us what size truck you have. Your links are broken, can you fix and re-post? Thanks, Mike B  | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | Ahhh, got ya. I guess I was thinking '55, the first series was the old body style, etc, correct? At any rate, it's a 6400. I'll try the pics again in a minute. The Series would be 4400, 6400, 8400, 10500 etc., this tells us what size truck you have. Your links are broken, can you fix and re-post? Thanks, Mike B  | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | Let's try this again: '56
| | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | OK I see the problem, the pic I was linking to wasn't "shared" in google photos, so I only I could view it. It should work for you guys now. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | GREAT looking truck! looks like some great assistants as well! | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | We've had fun with it. This is all the material I hauled to build a road into some land I bought, it was like a big sandbox for both kids and dad..haha road pic | | | | | Joined: Oct 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 47 | And this is another reason I'd like to have more power. Little small blocks just don't have enough torque sometimes...haha...although in cases like this I'll have to be careful to not twist a driveline. I had to use my tractor to pull it out from this spot. stuck | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | 8flat, That picture worked...nice truck! You have a 6400 Series 2-ton... If it were me, I'd drop a 350 in and call it a day, it's a simple swap since there's a 283 in it already. The 350 will do more than the truck can handle...if you overload the truck the 350 will still move it, the BIG problem will be stopping it! Fix the 2-speed rear and run it in low rear while loaded and switch to high gear for the empty run home. She will go 65 mph empty. Mike B  | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Mike B. with the stock rear end gears and 9R22.5 tires, that will go 65? Any idea what the RPM is at that speed? (winding up pretty good, I'd imagine? 3500 or so?) | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I had a stock '55 6500,with 9:00X20:00's,a 261,with a SM420 trans. Top speed was 55. I believe Mike B.'s truck does achieve 65,since he's mentioned that fact in several posts. But,yeah,I'd think that would be "winding up pretty good",in an otherwise stock drivetrain.
| | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | My Fire Engine has a 200 hp 322 V8 with a NP 5-speed (direct) and a 8.36/6.14 2-speed rear with 11.00 x 22.5 tires and I bump the 4000 rpm governer all the time and will run 62-63 mph at 35-3600. Oh, and it weighs 14,200 pounds without water in the tank. The Tow Truck with a stock 8.72/6.40 2-speed rear with 10.00 x 22.5 tires, a SM-420 trans and a 200 hp 350 V8 2-barrel will run faster than the Fire Engine as it doesn't have a governer and it weighs 4,000 pounds less. Maybe it's just the way I drive, I'm not afraid to get the rpm's up and keep them up as that's where my power is. I've been in lots of convoys with the ODSS Stovebolter's and they NEVER have to worry about leaving me behind! Mike B  | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Mike B. with the stock rear end gears and 9R22.5 tires, that will go 65? Any idea what the RPM is at that speed? (winding up pretty good, I'd imagine? 3500 or so?) Are you running 9.00 x 22.5's on a 2-1/2 ton truck? That sounds small to me, I would have thought they would be 10.00 or even 11.00's. And yes the rpm is up there! Mike B  | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 |  sorry about the 69cuda. You're good...9.00 x 22.5's are right at home on a 2-ton! So many guys with similar trucks and projects, I don't know why I can't keep it all straight in my head...lol! Mike B  | | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | 8 flat check out on you tube Mark Fugazzotto,and her on stove bolt has same truck with 7.3. He has modified a wiring harness that's great for 7.3 in a 49 6400. You will probably be able to offset your engine a few inches to the right to clear gearbox we both did.he has original front suspension,I have installed a P3032 IFS out of motor home. | | |
