1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
If convenient I wouldn't mind having the front half of a 48-53 (or 54?) GMC frame to help me figure out and modify the transmisison crossmember to suit my needs.
1 ton would be ideal but I think 3/4 through 2 ton uses same transmission corssmember, fits in the frame same way. Not sure about 1/2 ton.
All I need is from front engine crossmember to transmisison crossmember, though wouldn't hurt to also have crossmember behind cab.
Needs to be from a GMC because of the front engine mount.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Moderator
Moderator
2 Offline
How about a 51 3/4 ton Chevy?
The whole truck delivered to your shop in May, after we get the engine started at the Homecoming. Clean title in my name.
http://s893.photobucket.com/user/2-Ton/library/1951%20no%20bed
I'll get more pictures of the mounts later today.
Price will be discussed privately.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Thanks but no thanks, really needs to be a GMC because the front crossmember is different from a Chevy.
Also hope to turn up half or whole frame less the rest of the truck.
---All pictures---
Grigg,
I have the chassis from the GMC Sleeper Cab project that John had...don't remember the size...2-ton??? You're welcome to any or all of the frame members you want, unless you already took them off!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike, I think that truck being a 450 series has a much different frame and cross members, particularly the rear engine mount. I'll look at the pictures I have of that truck tomorrow. Do know we saved and reused a U shaped channel iron crossmember from just behind the engine which is why I'm pretty sure not same as a pickup.
Really just looking for enough of a 1 ton or comparable frame to fit an engine in and mockup and fabricate a different rear engine crossmember. Be a lot easier to do that with a short section of naked frame than one with a cab on it.
Grigg
---All pictures---
Moderated by  Bill Marlow, SWEET
