4 members (klhansen, 32Fordpuchoptop, FAST55, walter74), 95 guests, and 2 robots.
Topics128,120
Posts1,056,319
Members48,439
#1147881 02/02/2016 7:55 PM
I have the '54-'59 wiper arms and '54 wiper blades on my '50. Anyone know if there are better blades for these arms than what the vendors are offering?
On my 58 I had the 12 inch blade from obsolete Chevrolet. They lasted about 5 years with no use, just dry rotted on the truck. I found replacements at Oreilly auto parts. It is the classic trico 12 inch blade Part number 33-122.
I use Anco P/N 05325, stk no. 20-12.
Thank you cletis!
Carl
I don't know if this will work on your arms but I was tired of how newer blades fit on the Anco 41-01 arms I have on my 52. So I went to the junkyard and pulled the arms off of a 90 something chevy pickup and cut the ends off. Then I tapped them and screwed them to the arms I have. Now I can use the new style wipers.
Nice mod! I have a TIG welder, so I can weld those parts together.
Carl
I used a complete Austin/Rover cable drive set up on mine with spindle adaptors from a series one Land Rover with stainless wiper arms and blades.
I re-drilled the spring mount to increase the spring tension and they work just fine,even in west Scotland.
A dab of Rain-X always helps too.
(P.S. We do get a lot of the wet stuff.)
More pix on Flickr.
