| | | Forums66 Topics128,124 Posts1,056,334 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | I have the '54-'59 wiper arms and '54 wiper blades on my '50. Anyone know if there are better blades for these arms than what the vendors are offering?
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | On my 58 I had the 12 inch blade from obsolete Chevrolet. They lasted about 5 years with no use, just dry rotted on the truck. I found replacements at Oreilly auto parts. It is the classic trico 12 inch blade Part number 33-122. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I use Anco P/N 05325, stk no. 20-12. | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 |
| | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | I don't know if this will work on your arms but I was tired of how newer blades fit on the Anco 41-01 arms I have on my 52. So I went to the junkyard and pulled the arms off of a 90 something chevy pickup and cut the ends off. Then I tapped them and screwed them to the arms I have. Now I can use the new style wipers. | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | I don't know if this will work on your arms but I was tired of how newer blades fit on the Anco 41-01 arms I have on my 52. So I went to the junkyard and pulled the arms off of a 90 something chevy pickup and cut the ends off. Then I tapped them and screwed them to the arms I have. Now I can use the new style wipers.Nice mod! I have a TIG welder, so I can weld those parts together. Carl
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I used a complete Austin/Rover cable drive set up on mine with spindle adaptors from a series one Land Rover with stainless wiper arms and blades. I re-drilled the spring mount to increase the spring tension and they work just fine,even in west Scotland. A dab of Rain-X always helps too. (P.S. We do get a lot of the wet stuff.) 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
