0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 23 Member | | Member Joined: Jul 2000 Posts: 23 | Got my '66 panel sideswiped by an Allstate insured driver a couple of months ago. Damaged LF fender and L door bad enough to need replacement, and section behind door needs extensive work. Took to Allstate body shop, they could not find parts, I bought a used door, then Allstate sent out their appraiser and came back with $1300 offer. How do I get maximum money from them?
57 3/4 ton rat 66 C-10 panel 350 200R4 3.07 axle 68 C-20 dump runner, 250 4spd, 4.11 82 Camaro, 305, THM-200-R4 84 Monte Carlo, 350, TH350 EVERETT, WA
| | | | | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | It's unlikely you will have the appraisal raised. The insurance companies USED to have you get at least two bids for the work, and they would pay based on that. However, there was rampant fraud based on that system. So now they imploy there "OWN" adjusters, who estimate the cost of repairs. If additional damage is uncovered during repair, they will usually make allowances to the estimate. The unfortunate thing is that they base their repair estimate on the absolute cheapest repair parts. You may be able to raise their estimate if you insist on better quality replacement parts (ie. GM OEM parts). | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | If they are like most insurance companies it is worth money for them to simply get the claim closed. It may be worth while to do some homework and provide them with your number to begin negotiations with. If all else fails, let them know that you need to have any settlement run past your lawyer first. What ever you do, do not sign anything unless you are completely happy with the repairs, etc.... Ultimately, they are responsible for repairing your car back to the condition it was prior to the accident. Don't forget that. It seems simple, but they are well trained to get you to think otherwise and take a low ball settlement. Never never take the first offer.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
