Brrrr
place holder
0 members (), 187 guests, and 0 robots.
Topics128,274
Posts1,058,425
Members48,489
Trying to figure out how I'm going to approach a project. I have cab and most of the sheet metal for a 1938 1/2 ton. Frame and engine bad. Is it possible to find just a frame and engine? Do I have to/should I just buy a donor truck? Any ideas what a good, original frame with running original engine should cost me?
Thanks for any input!!
How rust free is your existing sheet metal and do you have it all? If you don't have it all or it's not good, look for a better truck and use yours as the parts donor...or look into puting your sheet metal on something like an S-10 chassis if original doesn't matter to you.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks mike.
A friend of mine put a 39 body on an S10 4x4 chassis and it looks pretty stock driving by or at a distance. 4x4, 4.3 V6, auto trans, and A C, pretty cool daily driver. Lots of donors out there. Scott
Look this up on the H.A.M.B. (Definitive S-10 Frame Swap Vehicle List) it might give you some help
Neverdone
Unregistered
Neverdone
Unregistered
Indy is right on the Lists on the HAMB but if you are going for a swap I suggest you just measure your wheel base and google it .. you will find all the vehicles with the same wheelbase and you may find some interesting ,and inexpensive possibilities
If going original a complete parts vehicle is the way to go , you may also find that the donor is better than what you have .
Also a Lot of the ""S-10 swap kits" listed in the HAMB posts are no longer in existence
Good luck
Dan
Thanks to all
There are also a lot of us here that are doing or have done the S-10 swap.
My 46 GMC on Photobucket
rolling chassis pop up on cr arround me all the time usuall 500 to 1000 with motor
thanks.
