8 members (MNSmith, lumbersawyer, Hotrod Lincoln, Shade Baby, klhansen, Mike B, 2 invisible),
123
Mod | | | Forums66 Topics128,139 Posts1,056,762 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | This system uses a vacuum booster,(firewall-mounted),witha dual reservoir brake system. I'd Guess bus is rated at 18,000#.http://chicago.craigslist.org/sox/cto/5412214867.html | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy wetwilly5757, When I open your link it takes me to an ad for a school bus motorhome conversion, I didn't see anything there to do with brakes? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | There is a picture of a master cylinder in the ad.. If looking for a donor for that sort of stuff there are plenty of options like it in various newer and more common trucks. First research if replacement MC and booster (from whatever you're looking at) can be had reasonably at the parts store to avoid swapping in expensive/obsolete parts. | | |
