6 members (RAC1812, klhansen, Gdads51, joe apple, tesa, Gray_Ghost), 54 guests, and 0 robots.
Topics128,077
Posts1,055,928
Members48,430
#1146455 01/25/2016 12:51 AM
After 3 years at the body shop,my part time body man man called. The doors that a friend who put new door skins on my 65c10 messed them up real bad. The body man showed me how the door lines don't match,and the tops stick out about a quarter inch,and the bottom is recessed about the same.This is on the bed end.The hinged gaps are also screwed up. I am probably going to buy new doors...any suggestions?
Can't you start over, cutting those skins back out and redoing with the lines sorted out? I guess it depends on how much money you need to spend.
~ HB
1962 Chevrolet C10
1962 Suburban
That would fix line problem. When he welded the skins he warped the doors pretty bad.
Oh. That makes things more clear.
~ HB
1962 Chevrolet C10
1962 Suburban
Try some of the suppliers on this site (4-5-6 Chevy comes to mind).
Be prepared even used doors are going to need work.
I know that I spent a lot of time getting mine in shape and I still need to figure out how to get a better seal at the top of the door.
Keep at it. It will work.
Crusing in the Passing Lane
Hammers and 2x4s come in handy for situations like that. Be surprised what a good body man can do.
Currently cruising
in the Passing Lane
Rest in Peace
Thanks for the info. I just have to do some more research and figure out what makes sense.
Save yourself some heartache and pepto bismal. There are doors out there that can make you sleep better and in the end may even save some money with better "end results".
Jay "Lugnutz" bought a truck recently. Not sure if its a parts truck or not but may be worth looking him up....and putting an ad in the Swap Meet Parts Wanted section.
...."I think we should get wiser as we get older" Good luck keep us posted.
I will contact him. I did find some doors from Aspen auto. I am talking to them about purchasing. Thanks again!
Sir Searchalot
Sir Searchalot
I agree with getting good donor doors(Alvin). Doors should be fitted/mocked-up/adjusted without ANY rubber or latches as far as X and Y. That way you know when you put rubber and latches on and adjust Z that it has to fit eventually.
The 1966 C10 I recently bought is in limbo for now. Trying to get a title. Nothing being offered for sale yet.
For one of my 1965 doors, I bought a large size door skin patch. The kind that goes from just below the window to the bottom. I found the fitment to be a fairly straight forward and things line up well enough for me, HOWEVER I found the skin was about 3/16" narrower than the original door. The front and back edges were already creased so I will need to add metal at the front and back edges to make the door gaps look right.
Also, the recess for the door handle was not as deep as the factory one. When I installed the handle, the plunger pin didn't quite reach the latch release mechanism enough to unlatch the door. I had to add length.
My advice is to find some original doors that are decent enough to repair. The hassle I had with mine was more frustration than I want to deal with. I am even considering replacing the one I repaired.
