| | | Forums66 Topics128,271 Posts1,058,414 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Trying to figure out how I'm going to approach a project. I have cab and most of the sheet metal for a 1938 1/2 ton. Frame and engine bad. Is it possible to find just a frame and engine? Do I have to/should I just buy a donor truck? Any ideas what a good, original frame with running original engine should cost me?
Thanks for any input!! | | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | How rust free is your existing sheet metal and do you have it all? If you don't have it all or it's not good, look for a better truck and use yours as the parts donor...or look into puting your sheet metal on something like an S-10 chassis if original doesn't matter to you. Mike B  | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | A friend of mine put a 39 body on an S10 4x4 chassis and it looks pretty stock driving by or at a distance. 4x4, 4.3 V6, auto trans, and A C, pretty cool daily driver. Lots of donors out there. Scott | | | | | Joined: Jan 2016 Posts: 12 New Guy | | New Guy Joined: Jan 2016 Posts: 12 | Look this up on the H.A.M.B. (Definitive S-10 Frame Swap Vehicle List) it might give you some help | | | | | | Neverdone Unregistered | | Neverdone Unregistered | Look this up on the H.A.M.B. (Definitive S-10 Frame Swap Vehicle List) it might give you some help Indy is right on the Lists on the HAMB but if you are going for a swap I suggest you just measure your wheel base and google it .. you will find all the vehicles with the same wheelbase and you may find some interesting ,and inexpensive possibilities If going original a complete parts vehicle is the way to go , you may also find that the donor is better than what you have . Also a Lot of the ""S-10 swap kits" listed in the HAMB posts are no longer in existence Good luck Dan | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | There are also a lot of us here that are doing or have done the S-10 swap. | | | | | Joined: Dec 2009 Posts: 8 New Guy | | New Guy Joined: Dec 2009 Posts: 8 | rolling chassis pop up on cr arround me all the time usuall 500 to 1000 with motor | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | | | |
