Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 44 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#1145891 01/21/2016 5:57 PM
Anybody have thoughts on doing some mig welding on your truck without disconnecting the generator? Just seem like a smart idea to not have any current flowing into it, battery is out on and the bench for the winter.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
doyle1950 #1145893 01/21/2016 6:06 PM
Sir Searchalot
Sir Searchalot
Take it off, a few wires, a few bolts. Never heard of it, but could happen if welding near it maybe, probably not. There are no high class, sensitive electronics in it. What about the coil, the points, the condenser, the radio, the regulator, the bulb filaments, the gauges, all the wiring, the fuses, the gas fumes...... smile
doyle1950 #1145900 01/21/2016 6:59 PM
If the battery is out on the bench , as you say , how is any current going to go thru the generator ?
doyle1950 #1145905 01/21/2016 7:31 PM
U
U Offline
Theoretically speaking-- from the electrical arc of the welding. Like Chief says, I also have never heard of it, but I'm sure somebody who knows somebody had a buddy-mechanic see a generator get damaged that way.
Something tells me you would have to be connecting the circuit by welding on the actual generator or mounts to cause any problems (to the generator).
Brad
Wrench Fetcher, PhD
doyle1950 #1145906 01/21/2016 7:37 PM
Generators are as tough as a 2-dollar steak. At worst, it might have to be re-polarized. Don't worry about disconnecting anything unless it makes you feel better to do it. OEM-replacement solid state voltage regulators definitely need to be disconnected or removed, however. Alternators, or any other solid-state devices- - - -definitely disconnect or remove them! Voltage spikes created by welding can, and do damage parts with diodes, transistors, integrated circuits, etc. That's particularly true of computers, CD players, digital clocks, or anything else with a constant-voltage "keep alive" circuit.
doyle1950 #1145942 01/21/2016 11:32 PM
Thanks that's kinda what I figured, with the battery out should be no problem.
Never hurts to ask as I may not be the only one on here learning about welding or rust-oration.
doyle1950 #1145949 01/21/2016 11:54 PM
Keep the welding ground close to your work and you should be fine, you don't want the welder arcing through any bearings.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
doyle1950 #1145968 01/22/2016 1:50 AM
Sir Searchalot
Sir Searchalot
"Never hurts to ask as I may not be the only one on here learning about welding or rust-oration." Truer words were never spoken. It's what this site is for. You are right, a question builds a post full of hints, tips and a learning experience for all levels.
