| | | Forums66 Topics128,186 Posts1,057,315 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I just received an update,from "cdandelivery" He's an instructor at the Dekalb School,(In Georgia),Where his class is restoring a '56 6500,that I posted a video of,on "Youtube" He just sent a couple of photo's of the 261 re-built! When I checked the truck out,the engine was "Stuck"! When I initially took the video of this truck,I figured someone may need a few parts,but I NEVER DREAMED that someone would haul it clear back to Georgia,for a complete restoration! WHAT A SAVE!! HAT'S OFF,To "cdandelivery",and his Class! https://picasaweb.google.com/108148341138770442418/Jan162016
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy wetwilly5757, when I tried to open the picasaweb it came up "page not found" | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks! I'll get that fixed! | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Here's the "Selling" Video...https://www.youtube.com/watch?v=h2pYa5RcFz4
| | | | | Joined: Jun 2009 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 60 | Thanks for the post students repro the decals by hand. Im always surprized at there ability. 1959 Chevy Viking 60 & WreckerIn the Stovebolt GallerySee I told you it would work. That Beaver Cleaver will do anything..... | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | What did it take to "free" the engine?? Did it need bored? My 261 had a 235 head,machined with the extra 261 steam holes. Take "Patrick's" Advice: Make sure you use a Zinc additive,(such as "ZDD"),along with an engine oil,engineered,(Zinc Added), for flat-tappet engines,(Valvoline VR 5W/50 Recommended).This is especially important during the break-in period. I Personally Recommend it every oil change. Some readers will disagree,but I changed the oil in my 261,every 1,000 miles,since it didn't have an oil filter. (S.C.O. Engine).The last oil change,I "listened" to another member,who had good luck,with an oil of his choice.I then switched to Regular Valvoline,and No Zinc additive. I spun a bearing 50 miles later. The engine had about 102,000 miles on it,though. Shoulda woulda coulda changed the bearings! Now the crank's TOAST!
| | | | | Joined: Jun 2009 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 60 | i soaked the cylinders for a few days with white vinegar. Which ate the rust loose from the rings.The head on this one was a 850 which had a 11 cracks! I took a 848 head from a 55 235 truck and we made the steam holes by the instructions posted in the archive section.The engine was in fair shape but was bored 30 over,hardened valve seats.One of my fellow college instructors bought out a old parts house in LA he had old stock on everything but the gaskets.... the exhaust manifold was cracked as well but after scouring the county side a great replacement was found.I decided to do a 54 2nd series 235 for our next feat.Funny it was missing the valve cover so we found one and got it to realize it didn't have a oil filler hole in it! Must have been from a 40 era truck oh well experiance is a great teacher!
1959 Chevy Viking 60 & WreckerIn the Stovebolt GallerySee I told you it would work. That Beaver Cleaver will do anything..... | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Are the pistons aluminum? White vinegar will eat dissolve vinegar.
| | | | | Joined: Jun 2009 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 60 | They were but so bad deteriorated the trick worked. occasionally I get some things to work despite the odds! 1959 Chevy Viking 60 & WreckerIn the Stovebolt GallerySee I told you it would work. That Beaver Cleaver will do anything..... | | |
