3 members (Lightholder's Dad, 2-Ton, TooMany2count), 83 guests, and 3 robots.
Topics128,024
Posts1,055,393
Members48,422
#1145570 01/19/2016 9:40 PM
I have a 15 * 7 wheels, 5 4 3/4 wheel pattern, backspacing is at 4 1/4. Tires are 225 75 15 cokers. My back wheels have about 1/4 if not rubbing are on the frame in the back. Fronts were hitting the tie rode ends but I took care of with 3/16 wheel spacers. If I go to 15 * 6 wheels with 3 3/4 backspacing do you think this would take care of spacing issue. Or does this tire on a 6 inch wheel still bulge out too far? Suggestions are needed.
Scott M.
What sort of suspension are you using? Stock? Aftermarket IFS? Also, what year truck?
Bill Burmeister
Truck is 1954 3100 1/2 ton. Rear end is a 1976 impala. Front end is the stock suspension with 3 inch dropped axle.
Scott M.
With the I beam, you'll want wheels with no more than 3 1/2" backspace, offset will vary depending on width.
Bill Burmeister
That's not really possible with OEM wheels. Less I go to 5 inch wheels any other suggestions I'm listening. Longer studs, spacers, less backspacing.
Scott M.
U
U Offline
OEM wheels from what?
Brad
Wrench Fetcher, PhD
From Wheel vintiques or wheel smith they do not offer a OE wheel less the 5 inch one with a backspace of 3.5. Not looking to go down to a 5 inch wheel. Spacers are looking more and more like the viable option.
http://www.wheelvintiques.com/index.php/o-e-chevy-ford-bare-finish.html
Scott M.
The OEM wheels for many years of Chevrolet truck pre '87 have a 3 to 3 1/2" backspace, depending on wheel width, which can go up t 8" depending on option. Wheel Vintiques can do custom backspacing on their wheels. The 3 1/2" falls within the range for most of their 6 and 7 inch wheels.
Bill Burmeister
Oooooooo.......good catch LongBox. I'll give them a ring.
Scott M.
