1 members (Hotrod Lincoln),
49
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | I have a 15 * 7 wheels, 5 4 3/4 wheel pattern, backspacing is at 4 1/4. Tires are 225 75 15 cokers. My back wheels have about 1/4 if not rubbing are on the frame in the back. Fronts were hitting the tie rode ends but I took care of with 3/16 wheel spacers. If I go to 15 * 6 wheels with 3 3/4 backspacing do you think this would take care of spacing issue. Or does this tire on a 6 inch wheel still bulge out too far? Suggestions are needed.
Scott M.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What sort of suspension are you using? Stock? Aftermarket IFS? Also, what year truck?
Bill Burmeister | | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | Truck is 1954 3100 1/2 ton. Rear end is a 1976 impala. Front end is the stock suspension with 3 inch dropped axle.
Scott M.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | With the I beam, you'll want wheels with no more than 3 1/2" backspace, offset will vary depending on width.
Bill Burmeister | | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | That's not really possible with OEM wheels. Less I go to 5 inch wheels any other suggestions I'm listening. Longer studs, spacers, less backspacing.
Scott M.
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | OEM wheels from what?
Brad Wrench Fetcher, PhD | | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | From Wheel vintiques or wheel smith they do not offer a OE wheel less the 5 inch one with a backspace of 3.5. Not looking to go down to a 5 inch wheel. Spacers are looking more and more like the viable option. http://www.wheelvintiques.com/index.php/o-e-chevy-ford-bare-finish.html
Scott M.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The OEM wheels for many years of Chevrolet truck pre '87 have a 3 to 3 1/2" backspace, depending on wheel width, which can go up t 8" depending on option. Wheel Vintiques can do custom backspacing on their wheels. The 3 1/2" falls within the range for most of their 6 and 7 inch wheels.
Bill Burmeister | | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | Oooooooo.......good catch LongBox. I'll give them a ring.
Scott M.
