| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So yesterday I pulled the 216 on my 38 to overhaul it. I used two headbolt locations to secure the lift and all worked as planned. Thinking ahead when I go to install it again, I will be using the same two headbolt locations. So my question is, should I torque all the headbolts and then remove two or should I just snug them all down and torque them after the motor is in place? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I use two bolts for the rocker-arm assembly posts (and a load-leveler on the lift). | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I have just torqued the two head bolts on several installations with no issues.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would also torque the after, and again after a good worm up.
See the USA in your vintage Chevrolet! My Blog | | |
