8 members (msmall, 68ironhead, Shardean, DannyW, Eisenholtz, 3800GUY, Shade Baby, cmayna), 41 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#1145379 01/18/2016 9:46 PM
So yesterday I pulled the 216 on my 38 to overhaul it. I used two headbolt locations to secure the lift and all worked as planned. Thinking ahead when I go to install it again, I will be using the same two headbolt locations. So my question is, should I torque all the headbolts and then remove two or should I just snug them all down and torque them after the motor is in place?
1951 1 Ton Completed
I use two bolts for the rocker-arm assembly posts (and a load-leveler on the lift).
I have just torqued the two head bolts on several installations with no issues.
Gas Pumper
Gas Pumper
After
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
I would also torque the after, and again after a good worm up.
My Blog
