0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
My 46 has a 2 speed differential. I would like to know what model it is and if the ratio can be changed or the pig replaced with a single speed with a better ratio. Just for reference I plan on installing a S10-T5 and the engine is a 270.
Crusing in the Passing Lane
The only ratios are slow and slower. No single speed third members are any better. Late model GM trucks exist with 5/10 bolt patterns(Dana 70 and 80) that have decent ratios you can easily replace yours with.
Ed
So there are no single speed rearends with 6 lug axles?
There are no single speed third members with higher ratios to fit your 2 speed housing. There are lots of single speed rears with good ratios. You probably have 8 on 6.5 bolt pattern, so lots of choices, single speed.
If you wish to change to 6 on 5.5, there are front and rear choices, too.
Ed
