| | | Forums66 Topics128,091 Posts1,056,392 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 11 New Guy | | New Guy Joined: Jan 2016 Posts: 11 | My 46 has a 2 speed differential. I would like to know what model it is and if the ratio can be changed or the pig replaced with a single speed with a better ratio. Just for reference I plan on installing a S10-T5 and the engine is a 270. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The only ratios are slow and slower. No single speed third members are any better. Late model GM trucks exist with 5/10 bolt patterns(Dana 70 and 80) that have decent ratios you can easily replace yours with.
Ed
| | | | | Joined: Jan 2016 Posts: 11 New Guy | | New Guy Joined: Jan 2016 Posts: 11 | So there are no single speed rearends with 6 lug axles? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | There are no single speed third members with higher ratios to fit your 2 speed housing. There are lots of single speed rears with good ratios. You probably have 8 on 6.5 bolt pattern, so lots of choices, single speed.
If you wish to change to 6 on 5.5, there are front and rear choices, too.
Ed
