| | | Forums66 Topics128,089 Posts1,056,366 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Does anyone have modern paint codes for the Brewster Green trucks in 1946? I suppose the Black is Black but a correct code would be nice. Lastly, I am interested in the Apple Green for wheels and belt line stripe. Al | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1946 Chevrolet Truck Brewster Green Ditzler/PPG 40042 Dupont 93-2015 http://paintref.com/cgi-bin/chipdis...ck&smodel=Truck&info=&page=1Apple Green Ditzler/PPG DQE379 Dupont 93-1650 Call PPG Color LIbrary and they might have a formula or a modern offset: try 1-800-647-6050
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Take a look at my 41 it is from Tim Sheridens color. I have marten signor Prism # if you want. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Dave, You have a very nice and straight '41 pick up. The color is exactly what I am after. My truck, being an early 1947 GMC, and a 1.5 ton, has the wheels painted apple green, the only difference in how your truck is painted and mine. I do assume that the Chevrolet's and GMC's are all painted with the same colors? What are you referring to "Marten Signor Prism #"? Is that a paint code? Is Tim Sheridan a paint shop? Al | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Tim Sheriden is a guy on this site, take a look at his truck, it is REALLY nice. Tim sent me paint codes for PPG I think but I could not get that so he sent me a spray out of his paint. Our local NAPA sells Marten Signor paint, they sent the spray out off to have it analyzed and I now have that mixing code. Prism is there top line of paint. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Hello Again Dave, Now I know exactly what you used. Is the Prism paint catalyzed enamel? I would certainly like to check your Prism numbers with our local Napa store. Al | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I sent pictures to your private email. I think prism is polyurathane. Catalyzed. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2014 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 36 | Napa sells Martin Senour paint. | | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | I have another question about proper paint color. What is the interior paint, for the dash door panels and other inside stuff that matches the dash cluster back ground, TAN? Al | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Did you get the codes you needed Big Al?
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Apr 2011 Posts: 3 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 3 | Actually, I would also like to get the paint codes for the interior paint on a 46 chevy truck. I know it is a "hammered" finish. Is there something that needs to be added to the paint to obtain that or can a place like O'Reilly's mix that, as they have mixed all my other paint. Also, is there a "trick" to painting that? Thanks | | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | Did anybody ever get a copy of the modern ppg paint codes for the Brewster Green?
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | The current PPG code for '46 Brewster Green is 40042. The current paint codes from PPG and the other companies are listed at this Paint Code link. Scroll down and click on the small paint chip to see it larger. Of course the colors aren't necessarily true on computer monitors, but it gives a pretty good idea of how light or dark the colors were. paintref.com also has copies of the vintage paint chip documents for many years and makes. For example, staying with '46 for the moment, scroll down a bit on this page for Martin Senour's '46 Chevy commercial paint chip page. Fun site to explore. Doug
