| | | Forums66 Topics128,080 Posts1,055,950 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 23 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 23 | Does anyone know the correct size for the wiper control knob retaining nut ?
Drew 1954 3104 3 window
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 |
1959 3100 Apache Fleetside
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | If the truck I took a nut off the wiper switch is a 54 (the VIN plate was missing), the nut is a smooth circular retainer with 2 opposing slots in the top. It measures 5/8 diameter and 1/8" thick with internal threads. If you want this, let me know it's a freebie.
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Nut is on the way to you.
