5 members (Wickedbass, treegrower, DoubleB, J Lucas, Phak1), 60 guests, and 1 robot.
Topics128,091
Posts1,056,033
Members48,433
#1144398 01/12/2016 6:31 PM
Just wondering if anyone has seen this pawl spring in on any parts vendors sites or if I need to try my hand at twisting 1 up?
The spring pictured is one I twisted up from coat hanger wire. I thinking it should be from spring steel/wire as this one just doe not have any return spring to it.
http://i1281.photobucket.com/albums/a512/doyleosborne/IMG_3196_zpskasgajqn.jpg
http://i1281.photobucket.com/albums/a512/doyleosborne/IMG_3198_zpskydueuz3.jpg
http://i1281.photobucket.com/albums/a512/doyleosborne/IMG_3192_zpsi3toe0xn.jpg
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
Check with Chevs of he 40s or even better The Filling Station!!
1946 1/2-Ton Chevy
There is a way to heat treat wire to make it into a spring. (I don't know if hanger wire is treatable.) Stand by, as a metallurgist familiar with the process may weigh in soon.
U
U Offline
Buy a variety pack of pedal return springs. Auto parts stores usually have them, and the springs are meant to be trimmed to fit.
It is already spring steel & there is 4" - 10" of excess straight material you can use.
Brad
Wrench Fetcher, PhD
