5 members (mason86, Oldcaliforniakid, Wally / Montana, Gray_Ghost, 1 invisible), 114 guests, and 0 robots.
Topics128,068
Posts1,055,883
Members48,428
#1144139 01/10/2016 7:52 PM
Any recommendations for a replacement spare tire changing jack for our 1952 1/2 ton Chevy pickup.
Chuck 52
Chuck52 #1144143 01/10/2016 8:21 PM
On long trips I carry a Craftsman Floor-Jack, Stand, & Case.
Here is the only similar combo kIt/case that I can now find.
Chuck52 #1144146 01/10/2016 8:46 PM
A small to medium size bottle jack would be a good choice. Or you could find an original type on ebay or swap meets. I think they used the same style for years, came with a long rod to turn the slot on the side.
1946 1/2-Ton Chevy
Chuck52 #1144153 01/10/2016 9:18 PM
Chuck,
Are you looking for an original-style jack? eBay or the Swap Meet are your best bet. Be patient. Here is info on the original 1952 jack.
Modern bottle jacks are hydraulic - original-style bottle jacks were screw/mechanical.
A bottle jack is OK on level/smooth/solid ground.
A floor-type jack (if you are OK with non-original appearance) might be safer on less-than-ideal ground (and, jack stands increase safety, after you get the wheels off the ground).
Tim,
I have a floor jack, but want to have something hidden away for emergencies when on tours. I'm thinking a type of bottle jack stored under the seat would be an "in case" insurance. I've just found an under bed carrier and purchased a new original spare tire spare. Again, thank you for the advice.
Chuck
