Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TexasJim50, Peggy M, Woodcmiami, farmallb, WICruiser, 66flea), 45 guests, and 4 robots.
Topics128,010
Posts1,055,299
Members48,419
#1144014 01/10/2016 12:31 AM
When I removed oil pan to reseal it, this bushing/spacer/washer fell out and I have no idea where it goes. This is a 1949 engine.
Size is approximately 1/2" to the outside 5/16" on the inside and 1/4" thick. see pics
Any ideas?
thanks 49nut
https://www.dropbox.com/l/s/wPmenbtvtHd4ITK0vARNHt
https://www.dropbox.com/l/s/4Sf31CTN6hWeEpjm0IKdlp
49nut #1144022 01/10/2016 1:31 AM
That bushing goes under the throttle return spring bottom mount/clip. It holds the mount so it clears the outer flange on the pan. There should have also been a longer pan bolt at that position.
My Blog
49nut #1144032 01/10/2016 2:03 AM
Thanks it kind of fell out of no where HA HA !
49nut
49nut #1144047 01/10/2016 3:00 AM
I never knew such a bird existed! Now I understand why I have always wrassled with getting the spring to go in the hole in that mount/clip.
I'll bet a lot of them got misplaced the same way 49nut almost did.
Carl
