| | | Forums66 Topics128,138 Posts1,056,751 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I am trying to decide if I should get a chrome or stainless bumper for my 41, any experience or thoughts which way to go? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Chrome these days does not seem that great, could be good sources I guess? I think SS will last you the long haul if you can accept the price difference. | | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Brad, Where is a source for the SS bumper correct for a 1941? Al | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I have seen several sourceses from the usual suppliers. Filling station is one, but there are others. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Oct 2007 Posts: 12 New Guy | | New Guy Joined: Oct 2007 Posts: 12 | I'll chime in on this one. My opinions are based on countless discussions with a friend who worked in a chrome shop for a number of years and then opened his own polishing shop where he does show quality trim straightening and polishing of stainless steel trim.
Chrome, pros: Luster: chrome shine has an unmatched depth to it Color: chrome has a slight blueish tint to it Chrome cons: If you bend it or scratch it you are done. Want it fixed? Send it back to the shop to have all of the chrome ground off, straighten the piece and re chrome. If damage occurs that breaks through the chrome and nickel layers the underlying steel will begin to rust and the chrome will peel off.
Stainless cons: doesn't have that blueish tint, however it also doesn't have the yellow of nickel, I would call it color neutral. Possibly a bit less depth of shine, I really can't describe this without pointing to a piece of chrome next to a piece of polished stainless. 99.9 percent of car nuts will never know the difference. Stainless pros: Got a scuff or scratch without a dent.? Get out the sandpaper and polishing compound and take it out in the same manner hat you buff out paint. A lot harder surface and you probably start with a more aggressive grit but the concept is the same. Bend or dent? The chrome/polishing shop can fix it just like they did with the chrome bumper but without the labor of grinding off the existing chrome or the expense of replating it. As he EPA gets increasingly out of control chrome plating is likely to become prohibitively expensive or shut down entirely.
With all of that said I have not seen any examples of stainless bumpers and I would expect that out of the box they will not have a show quality shine, but here again, get out the polishing compound and buff it out.
I hope that someone finds this helpful.
40 chevy 1.5 ton, 50 chevy 3/4 ton, 67 chevy stepside 1/2 ton, 67 C50, 68 C50, 73 chevy 4x4 3/4 ton, 2004 Silverado 1/2 ton , 2005 HD 3/4 4x4 Duramax (don't even get me started about my Oldsmobiles!)
| | | | | Joined: Oct 2007 Posts: 12 New Guy | | New Guy Joined: Oct 2007 Posts: 12 | One last comment regarding low quality stainless, although it won't rust, it can get tiny pits in it that are visible if you look really close. I'll chime in on this one. My opinions are based on countless discussions with a friend who worked in a chrome shop for a number of years and then opened his own polishing shop where he does show quality trim straightening and polishing of stainless steel trim.
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | I see several sources for SS and repo. chrome bumpers for the 41-46 trucks. Does anyone know if they are even close to the originals as far as curve, length and bolt up. I am referring to fit to our big trucks not the pick-ups of the same vintage. Al | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Have to be careful with chrome, to be done properly, must be cleaned, Cu plated, polished, Ni plated(Model A Ford) then chrome. Some cheaply, offshore people only do the chrome, starts rusting right away.
Ed
| | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Ed, you are very correct in your statement regarding the plating process. I was on the phone, with a plating shop in SLC, this morning checking on chrome plating some stamped aluminum caps for another project. It does pay to know your plater and ask questions before you spend any money! Nothing worse than to spend good money and then see rust come up shortly.....GRRRRRR. Still wondering about the fit of the new "Repo" bumpers, both in polished SS and Chrome plated steel, on our larger trucks 1941- early 47. I am not anxious to ask desk help at one of the vendors as they may have no idea other than what they are told. Al | | |
