1 members (klhansen), 90 guests, and 3 robots.
Topics128,151
Posts1,056,999
Members48,460
Here is the problem when you move something from one shop to another. Trying to mate the transmission to the drive shaft, you will see both have male ends, so a coupling must be needed. Somehow it has been lost or something. Does anyone know where i can find a replacement or am i screwed? Any idea what its technically called?
[img]http://i.imgur.com/gcbrEv1.jpg[/img]
[img]http://i.imgur.com/0V5DXhX.jpg[/img]
1950 Chevy 3600
3B Offline
Hy Bradw1876, what you need is the forward universal joint assembly which will include the two female yokes, hope that helps.
Any idea where to find this mythical part. haha.
1950 Chevy 3600
It is a little more common than hens' teeth.
Do you have a 3-speed or 4-speed trans, it makes a difference.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Check Ebay...
4-speed p/n 3689288
http://www.ebay.com/itm/1947-1954-Chevy-Truck-U-joint-3-4-Ton-4-speed-NIP-/151923432563?hash=item235f579c73:g:~ScAAOSwA4dWJqs6&vxp=mtr
3-speed p/n 591646
http://www.ebay.com/itm/1941-1953-chevrolet-commercial-3-4-ton-nos-u-loint-1947-1948-1950-591696-/111865429630?hash=item1a0bb2fe7e:g:OKIAAOSwZjJU4PaZ&vxp=mtr
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Originally Posted by Mike B
Check Ebay...
4-speed p/n 3689288
3-speed p/n 591646
Mike B smile
Awesome thanks Mike! So I know my 235 is out of a 58 Chevy and I am not sure if the transmission is as well. I know the drive shaft and the transmission have 10spline shafts. Do you think the part you listed for the four speed will work?
1950 Chevy 3600
Brad,
The driveshaft yoke's are the same for 3-speed and 4-speed's, it's the trans yokes that are different. You still haven't said if you have a 3 or 4 speed???
If in dought ask the seller to measure the diameter and count the splines of their yokes and confirm with what you have.
My guess is if you have a 4-speed, the 4-speed joint will work.
Let us know how it work out!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
4-speed as per Double Post
I missed that, sorry...
Here's a used one on eBay for $70.00
http://www.ebay.com/itm/1948-1953-CHEVROLET-3-4-TON-TRUCK-UNIVERSAL-JOINT-U-JOINT-3689288-/331596799035?fits=Make%3AChevrolet%7CModel%3ATruck&hash=item4d34b59c3b:g:kywAAOSw-vlVlci5&vxp=mtr
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
Thanks Mike
1950 Chevy 3600
